It is currently Wed Aug 13, 2025 5:23 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Tue Aug 04, 2015 5:31 pm
patch wrote:
I guess I should have been more clear. Why chamfer the bridge at all? What are the benefits?
Chamfering the bridge pin holes lets you fit the pins closer to the bridge and they look better IMO.
PostPosted: Tue Aug 04, 2015 8:02 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
When I say my tooling and approach is pedestrian, I mean it. The bit wobbles in the holder till it contacts the hole, finds its own center. Press a few times, and I'm done. Total investment maybe $5. And yes, do it. It just looks better.
PostPosted: Wed Aug 05, 2015 8:38 am
Seems you are getting good results with that bit -- however without the pilot feature that style bit has the tendency (in all applications) to produce a pentagon shaped hole pattern, resulting from improper feed and speed chatter. Just a warning for those thinking of trying it.
Ken Cierp
PostPosted: Wed Aug 05, 2015 10:45 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Michael.N. wrote:
As someone once said, the fingers don't care. They want to feel the centre of the string, the fingers aren't concerned with whether the strings 'look' right. On a Classical I doubt that it matters either way, there's so much space between strings. On a SS things may be different, maybe there's a need for a touch more wiggle room on the wound strings but SS certainly aren't my forte.
My left hand fingers see it differently. They want to fit in the space between the adjacent strings. If that space varies, then that becomes more difficult. If anything, the larger strings need an exaggerated amount of space between them because they vibrate more widely. (The really crucial point is that your fingers must all be exactly the same size.)
PostPosted: Wed Aug 05, 2015 11:03 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Eric, you're fingers might be more cooperative if you took those big mittens off. . . :)
Bryan Bear PMoMC
PostPosted: Wed Aug 05, 2015 10:21 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
No doubt, using it in tight chuck, hand held drill, you won't like the result. That's why I mentioned the process. Not everybody has a drill press, so Ken's warning is well advised. So, please add $1000 to my tooling cost (drill press). ;) ... Or buy the $32.50 chamfer but from SM
Note: I'm not a snob. I'll probably buy that bit because I can't help myself.
PostPosted: Wed Aug 05, 2015 10:25 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Yup
PostPosted: Thu Aug 06, 2015 1:34 am
That T.A.S. is a terrible thing.
laughing6-hehe
PostPosted: Thu Aug 06, 2015 10:42 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Martin used to drill the bridges with equal spaces between the strings, but I think that stopped when the necks were narrowed in 1939. Today, every Martin I have checked is equal centers.
In addition to allowing the bridge pins to be set lower, countersinking the holes prevents chipping. I also do it on end pin holes.
My favorite countersink to do this is a four flute that has a 1/2" shank. I turned the shank down to 3/8" so I could use it in a hand drill. It works equally as well in a drill press or with a hand drill. No chatter.
PostPosted: Thu Aug 06, 2015 12:00 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
Well, it's an amazing thing. You would think the mittens would be a real handicap, but most people are surprised at how little my playing improves when I take them off.
PostPosted: Thu Aug 06, 2015 1:34 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Sounds like we should jam sometime!
Bryan Bear PMoMC
Users browsing this forum: Melt in the Sun, Michaeldc, Mike Thomas and 33 guests
